Need some cam help. Adding 1.7 rr's to CC306?
Old May 19, 2005 | 06:01 PM
T/A lt1's Avatar
I was thinking of swapping cams for some more lift but I fiquered why not just add some 1.7 rr's like the bolton guys do and my CC306 will have 570/600 instead of 540/570. You guys think it will make more power on the n2o with some more lift? LMK what you guys think. later Clint
Old May 19, 2005 | 07:36 PM
grygst76's Avatar
Re: Need some cam help. Adding 1.7 rr's to CC306?
Better get longer pushrods too while your at it
Old May 20, 2005 | 02:04 PM
Black_95Formula's Avatar
Sounds good, just make sure your springs can take the added lift. And yes, it will def be good for more power.
Old May 20, 2005 | 02:15 PM
T/A lt1's Avatar
Well looks like my springs are 987's which may coil bind at 600lift so I may have to scrap this idea. I think it may only make 10HP or so anyways so I may just swap the cam and springs later. Clint
Old May 20, 2005 | 02:17 PM
96m6lt1's Avatar
i would go for it ! however i spoke with my head machinist here and he said that "in order to have the proper geometry you need to measure the pushrod length,may have to go to a .100 long and you have to check the retainer to guide clearance and of course have strong enough springs"
Old May 20, 2005 | 04:23 PM
redcamaroz28's Avatar
I've read the k-800 springs are good up to .700 lift.
Old May 20, 2005 | 04:45 PM
BUBBA's Avatar
What about piston to valve clearance? I don't know if there are any issues, but I'd sure check it out.JMHO
HarleyZ28
Oct 5, 2015 06:23 AM
StansZ28
Feb 19, 2015 07:39 AM
Cam's maro
Jan 30, 2015 09:21 PM
