Need some cam help. Adding 1.7 rr's to CC306?
I was thinking of swapping cams for some more lift but I fiquered why not just add some 1.7 rr's like the bolton guys do and my CC306 will have 570/600 instead of 540/570. You guys think it will make more power on the n2o with some more lift? LMK what you guys think. later Clint
Re: Need some cam help. Adding 1.7 rr's to CC306?
Well looks like my springs are 987's which may coil bind at 600lift so I may have to scrap this idea. I think it may only make 10HP or so anyways so I may just swap the cam and springs later. Clint
i would go for it ! however i spoke with my head machinist here and he said that "in order to have the proper geometry you need to measure the pushrod length,may have to go to a .100 long and you have to check the retainer to guide clearance and of course have strong enough springs"
