Need Some advice Please!
Old Apr 23, 2008 | 08:16 PM
rockstarjoey's Avatar
Check Engine Light came on the other day on my '97 Z28....So I ran a scan on it! showed 3 codes ,got rid of of 2 of them but cannot erase this code (p1441 -manufacturer specific code).....how can you eliminate this code? HELP!
Old Apr 23, 2008 | 09:24 PM
P1441 Evaporative Emissions (EVAP) system flow during non-purge
This means that vacuum flow was detected in the EVAP system when there was supposed to be none. This could mean that the EVAP solenoid (#7) is stuck open or even the two hoses going to the solenoid are reversed (perhaps you did some recent work and put them back wrong).
It could also mean that the vacuum switch (#11) is faulty.
You should also check for presence of any charcoal granuals in the vacuum hoses.
http://shbox.com/1/1996_evap.jpg
The DTC link in my sig has f-body specific codes definitions.
Old Apr 24, 2008 | 08:02 AM
Warren_Seale's Avatar
Also check your gas cap, make sure it is on tight or it is not leaking. I had this problem with my daughters Cavalier and it turned out to be the gas cap. The fuel tank is supposed to be unvented until the solenoid opens to vent the vapors.
Warren
Old Apr 24, 2008 | 11:53 AM
Thanks for your help guys ,I will look into it!
Jeff1904
Jun 5, 2016 05:00 PM
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
