Need part # shoebox.....
Old Sep 4, 2003 | 03:22 PM
Cmr0z28's Avatar
when I adjusted the wiper arm, the piece at the front of the arm cracked, probably from being brittle from the sun. is there a separate part number for this? (its about 4 inches long and clips in to the front part on top of the arm, i can get a pic if you'd like)
or do I need a whole new wiper arm?
Old Sep 4, 2003 | 11:09 PM
Cmr0z28's Avatar
ttt
Old Sep 4, 2003 | 11:18 PM
SWINGRRR's Avatar
Are the numbers on them not P/N's? Mine show DRV side-22122606LH Pass Side-22122607RH Hope this helps.
Old Sep 4, 2003 | 11:28 PM
Cmr0z28's Avatar
I tried them in gmpartsdirect.com, but no results. thanks anyway
Old Sep 4, 2003 | 11:32 PM
The cap that goes over the mounting nut?
GM PART # 22122401 RH
GM PART # 22122402 LH
That's the only other part I see besides the arms:
GM PART # 22155458 LH
GM PART # 22155459 RH
Old Sep 4, 2003 | 11:43 PM
SWINGRRR's Avatar
Mine is a 93. I wonder why they have different P/N's?
Old Sep 4, 2003 | 11:46 PM
Cast or embossed numbers on a part are not always indicative of the real part number. Plus numbers can change over the years, as well. The above numbers are listed for 93-97.
Old Sep 4, 2003 | 11:53 PM
SWINGRRR's Avatar
Gotcha Thnx
Old Sep 5, 2003 | 12:14 AM
Cmr0z28's Avatar
thanks
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
