Need Opinions on Oil Cooler...
Old Feb 12, 2005 | 07:00 PM
BoobSter-lt1-z's Avatar
Exclamation Need Opinions on Oil Cooler...
I was wondering what everyones opinion is because I am leaking a lot of oil from the oil cooler and the mechanic said it was the seal :
SHOULD I
-1- Remove it myself and delete it?
-2- Have the mechanic remove it?
and if I do have it removed can I still use the HP 2002 from KN oil filter?
or
-3- Should I have the oil cooler gasket replaced?
If I do end up removing the oil cooler myself is there a thread or book that will show me step by step? I am one of those guys that knows just the bare
basics of mechanics....
THANkS A LOT IN ADVANCE!
Old Feb 16, 2005 | 01:52 PM
Re: Need Opinions on Oil Cooler...
Ttt
Old Feb 16, 2005 | 02:00 PM
BUBBA's Avatar
I'd get rid of it. Several have deleted it. Altjar is one, I believe.
Old Feb 16, 2005 | 02:52 PM
aNY SPECIAL PARTS THAT I MUST BUY OR EVERYTHING WILL HOOK RIGHT UP AS SOON AS I REMOVE THE BOLTS AND PULL IT OUT...? AND THE SAME
HP -2002 K&N OIL FILTER WILL FIT
Old Feb 17, 2005 | 01:16 AM
atljar's Avatar
You need to pull off the cooler and splice together the coolant lines.
The filter i recommend is the larger almost 1 qt filter, not sure the number for the KN. Its application is listed as GM 2500 trucks (most years, do 1995. They all run the same filter). I run the Napa Gold filter (made by Wix). Its part number 1060.
http://www.napaonline.com/cgi-bin/nc...grpid=63351131
you should also see a decent gain in oil pressure by removing the cooler.
Old Feb 17, 2005 | 08:34 AM
Thanks A lot for the reply...
So those (2) alluminum lines that connect to the black block (which i believe is the oil filter) have to some how get hooked up together right?
What did you use?
Old Feb 17, 2005 | 08:47 AM
flusz28's Avatar
you have one cooler line going from the lines to the right bottom of the radiator, the other goes up to the water pump. unbolt the cooler and remove it. get a oil cooler bypass hose which gets put on the water pump elbow then runs to the spot i told you for the radiator.
Old Feb 17, 2005 | 11:47 AM
So when the oil cooler is removed both of the lines will still be intact to the
oil cooler and i must disconnect the line at the radiator and the water pump elbow and use that oil cooler bypass hose and hook it up to the radiator and
the other end to the water pump...
sorry for making it so complicated...I dont know much about working with
cars so sorry for the slow understanding...
This bypass valve, is it sold at an autozone? Is it a universal one size fits
all?
Should i expect all my oil to leak out when replacing this or just whats in the
oil cooler and filter...
Old Feb 17, 2005 | 07:38 PM
flusz28's Avatar
your feedback is correct- its called a oil cooler bypass hose- forget the part number. autozone should have it, explain it to them. only thing that will leak out is antifreeze- no oil.... remember when you pull that hose of the radiator and water pump you will have fluid everywhere. best to drain the whole system and add new stuff to the system. email me of you have any other questions.
Old Feb 18, 2005 | 08:35 AM
Alright!
Thanks....
Ill post some info when I am done...
Not sure if ill be doing the throttle body mod and oil cooler removal the same day but they will be done next weekend..
thanks!!!!!!!!!!
HectorM52
Jul 30, 2017 11:46 AM
FredM
Jun 5, 2015 05:45 AM
carl.froehlich
Mar 13, 2015 12:38 AM
ssbee
Jun 12, 2002 12:03 PM
