Need More Voltage, Help!!
Old Oct 4, 2004 | 07:10 PM
OnefstCamaroZ28's Avatar
Banned FOR SCAMMING - Nick[William] Dascal - (516) 931-0586
When my car idles my voltage is like at redline, bottom redline. I need more voltage. My alternator is pretty good, it keeps the car running without the battery connected. What would I need to change this besides a better alternator.
Old Oct 4, 2004 | 07:12 PM
'94 Bad A Z28's Avatar
Re: Need More Voltage, Help!!
My car does that too, and I have a 160amp alternator, so I don't know.
Old Oct 4, 2004 | 07:17 PM
944v8inDFW's Avatar
it may actually be the guage. get a voltmeter and check it or ...cough cough... go have it checked at autozone. The 10 year old guages in your car can not always be trusted
Old Oct 4, 2004 | 07:30 PM
n2ceptor's Avatar
Might be the voltage regulator..... With the car running, voltage should read around 13.8~14.2... Its an internal regulator, not easy to replace, from what I hear...
Old Oct 4, 2004 | 07:33 PM
And, my alternator does a **** poor job if charging my battery
Old Oct 4, 2004 | 07:44 PM
tom2's Avatar
If you've run the engine with the battery unhooked the alternator might be toast. The high power alts. don't last long with a low/no resistance load. Also, do you have underdrive pulleys? They will cause this especially with the fans running.
Old Oct 4, 2004 | 07:47 PM
944v8inDFW's Avatar
good points
Old Oct 4, 2004 | 08:00 PM
Z95m6's Avatar
If its really low then you have a major problem. My car would only show about 12 volts and it ended up being the fuel pump. As they age they eat up more juice. I bought the a new Racetronix pump and alternator harness and all is good. Adding the harness to my car with the old fuel pump bumped my voltage up to 13.5.
RUENUF
Mar 13, 2016 03:37 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
Aug 7, 2015 01:26 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
