Need LT4 (preferably) or LT1 .bin or .lt1 file
Old Jan 19, 2004 | 02:00 PM
ULTM8Z's Avatar
Does anyone know where I can find this file? I just put a TPIS MiniRam (very similar to an LT1/LT4 manifold) on my ZZ4 and wanted to see the entire calibration for a 4th gen engine. I managed to find the spark timing tables and converted it into a bin, put it in my calibration and MAN what an improvement. The LT1/LT4 cal has to be a good starting point for tuning.
Thanks!
Old Jan 19, 2004 | 02:15 PM
Shon Herron's Avatar
LT4 is an OBDII file. Do you have the ability to read this or just OBDI files?
I am not sure what the difference between the LT1 and LT4 files are but I can not imagine that much.
Old Jan 19, 2004 | 02:26 PM
ULTM8Z's Avatar
I downloaded some software that converts .lt1 files into .bin files for viewing on programs such as Tunercat.
As far as differences, I imagine that the LT4 has slightly more aggressive fuel/spark tables than the LT1 in order to take advantage of the better heads, camshaft, and manifold.
Old Jan 19, 2004 | 02:51 PM
This only converts the file extension, not from OBDI to OBDII. Totally different events....
And the changes are nothing more than you can do on your own. but a guide is nice.
Old Jan 19, 2004 | 02:53 PM
ULTM8Z's Avatar
Actually, my goal is to simply see the numbers in the LT4 tables and simply do a cut and paste into my own calibration using TunerCat. I realize that the file itself is incompatible with a 7730 style OBDI ECM.
Old Jan 19, 2004 | 02:57 PM
Unless someone has already done this the software you speak of will not allow you to do that.
LT1edit has 2 versions, OBDI and OBDII. (Now if you have both versions I am making an *** of my self....)
Tunercat will only view OBDI files.
LeftoverChinese
Jan 14, 2024 03:03 PM
NewsBot
Jan 21, 2015 06:10 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
NewsBot
Dec 3, 2014 12:30 PM
