NEED LT1 helps ASAP
NEED LT1 helps ASAP
Well I did a H/C on my camaro with a LT4 hotcam kit stock heads with 1.6RR 1.60 and 2.02 valves and SLP headers, and when I got my car out the shop it ran like a champ but within 2wks now my car under load feel like it a rice rocket. IT sound and and is running different. They think it may be the opti spark but not sure. What do you guys think. when I put it on nuetral it rev fine but when you drive and punch it to WOT it pauses over and over. I check fuel pump and pressure at 38 and everything else has been change within a yr or less. I wanna know what you guys think before I have to buy what ever it is. Opti an cheap so hopefully it aint that. You can email me or post your opinion but I wanna know if anyone have had the same or close to same situation as I have, and let me know what you did or what fix it.
Re: NEED LT1 helps ASAP
Originally Posted by Birdman7389
You have any kind of computer tune? I'd imagine the car would run pretty bad with the above parts and a stock tune.....
Originally Posted by '97SLVRBullet
Why would that need to be done? It should have been done with the mods.
This, no doubt, has nothing
to do with your problem, but notice that your valves are pretty big for a stock head. I assume that valve seats were ground to accept the larger valves and unshrounding was done.
ro2207
Dec 4, 2014 06:18 PM
