Need LT1 help ASAP
Old May 8, 2004 | 03:14 AM
SJBlackZ28's Avatar
Need LT1 help ASAP
Well 2 day I was driving home from work when out of no where my car turn off so I drift to the emergency lane. I chill for 2mins and turn the key and just doesnt want to start. It cranks but doesnt wanna turn on. What do you guys think it is? Also less then a month I did my tune up. Any opinion of my problem. Car has 160k and only trany and opti and water pump have been change recently. I been running nitrous for 2 months so hopefully my block no out but let me know what you think it might be.
Old May 8, 2004 | 03:53 AM
turbo_Z's Avatar
could be a lot of things but id suspect fuel pump or naturally the opti.
Old May 8, 2004 | 03:56 AM
david97gsxr's Avatar
a friend of mines 94 Z28 did something like yours, where it would just die going down the road.
it was the coil, and coil wire.
his car has 190K original opti.
Old May 8, 2004 | 07:44 AM
n2ceptor's Avatar
Opti did it to me at 125,000 miles..... Bearing failure and rust on the disk....
Old May 8, 2004 | 08:14 AM
gb95zconv's Avatar
Can you here the fuel pump cycle when you turn the key?(just turn the key dont crank it over).
Check coil, coil wire , Ignition module, major ground points.
Old May 8, 2004 | 08:20 AM
Bad64chevelle's Avatar
Same thing happened to me...it was the Ignition Control Module. I had recently changed the coil...but check if you are getting any spark, try that and if you are getting spark move onto the next thing, fuel etc.
Old May 8, 2004 | 08:58 PM
HBHRacing's Avatar
you can use this to figure out what your missing
http://mainstreamtopics.com/forum/in...p?showtopic=78
Old May 9, 2004 | 02:18 PM
SJBlackZ28's Avatar
I'll check the fuel pump then I'll move from there and let you guys know the statis. Thanks for replying and ur guys help. Hopefully it something small not major.
Old May 11, 2004 | 12:23 AM
SJBlackZ28's Avatar
Well I havent had a chance to check my car due to mother day and work but I will soon. If my motor went out how could I tell??
Brake_L8
Jan 20, 2015 09:44 AM
ro2207
Dec 4, 2014 06:18 PM
TA Jack
Sep 14, 2002 01:28 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
