Need LT1 Head Gasket Recommendations (& other gaskets for that matter)
Old Sep 19, 2010 | 05:18 PM
350350's Avatar
So I'm finally about to put my LT1 back together. I wish I had an awesome LT1 build thread story to tell you... but I don't. It's going back together stock and even that took months to save for.
I'm assuming I need to use at least GM or better head gaskets. I can get GM of course easily enough, but is there any benefit or need to do 'better'? And if so, who makes better? Keeping in mind it's a stock engine with stock compression.
And for that matter, all the rest of the upper end gaskets. The exhaust gaskets were metal shims, and that was new to me. This is my first aluminum head engine though. Should I just get an entire engine gasket set from GM?
Old Sep 19, 2010 | 06:43 PM
plattted's Avatar
gaskets and such
Use Felpro gaskets -many options with them.
Old Sep 19, 2010 | 08:51 PM
brucer's Avatar
you could use the .026 victor reinz head gaskets to bump your compression up a little..
Old Sep 19, 2010 | 08:55 PM
350350's Avatar
This is all uncharted territory for me... back in the olden days, thinner head gaskets also meant more likely to blow.
But the LT1 gaskets on my car had metal on all the prominent edges. Seems like the only way to blow that is with warpage. Which is what mine did.
So maybe nowadays, thinner really doesn't make them any more likely to blow?
Old Sep 19, 2010 | 09:07 PM
94EvilZ28's Avatar
Hey if you need some...I have some stock new head gaskets laying around...I got the engine in the sig now...so they dont work...PM me if you are interested...I will make them cheaper than any store or place you can get them.
James
Old Sep 19, 2010 | 09:14 PM
brucer's Avatar
if your heads are flat i would use them...
modern head gaskets are far better than the old steel shim head gaskets..
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
Snoman73
Nov 17, 2014 07:22 PM
