Need to know what this sensor is for??
Old Jun 20, 2005 | 06:39 PM
rsjay's Avatar
There is a orange 4 prong sensor that is on the passenger side near the PCM. It is coming off the same harness for the relay fan. What does this connect too? I can't seem to find anything it does. Also there is a small wire next to it for the fuel. What does that connect too?
Old Jun 20, 2005 | 09:23 PM
Re: Need to know what this sensor is for??
Please provide year.
Are you sure it is not an 8 wire connector?
There is a small wire nearby for priming the fuel pump. It has no connection.
There is a clickable harness picture on my Tech Page.
Old Jun 21, 2005 | 05:12 AM
rsjay's Avatar
Yes I forgot to mention the year. It is a 1994 LT1 Camaro. On your webpage it is sensor C105 near the fan switch. Do you know what that is?
Old Jun 21, 2005 | 07:56 AM
C105 is not a sensor. It is a harness connector. Look at the harness connector faces page on my website for a description of what is in it.
[edit] Sorry, I just realized there is not a listing for 1994. I don't think a 1994 has a C105. You are probably going to have to post a picture and give wire colors or wait for someone with a 1994 to respond.
Old Jun 21, 2005 | 05:10 PM
rsjay's Avatar
Shoebox. It is a harness connector. Sorry for the confusion. What does that connect to?
Old Jun 21, 2005 | 05:22 PM
Dave89IROC's Avatar
i'm in the garage now, just looked at both a 94 Z engine harness and the body harness, there is no orange 4 pin connector near the pcm, there is a black 8 pin with a orange seal, which connects the engine harness to the front harness, can you take a pic?
Old Jun 21, 2005 | 05:31 PM
rsjay's Avatar
Damn camera is not working but that is the one. I am saying 4 pin when it is actually 4 across top and bottom with a orange seal. Where does that connect to? I can't seem to find the other connection.
Old Jun 21, 2005 | 05:56 PM
Dave89IROC's Avatar
the mating connector comes from the front harness, over the shock tower from around the batt area, it is the same harness as most of the fuse links at the red junction post
Old Jun 21, 2005 | 07:46 PM
rsjay's Avatar
Dave. I just spend 45 minutes out there and I can't find anything that connects to that 8 pin connector. I checked around the battery, down by the headlights and nothing. Unless it is stuck between something there. I did have the motor out and just got it back in and this is the only connection I can't figure out.
Old Jun 22, 2005 | 07:47 AM
Dave89IROC's Avatar
is it the original engine harness?
Old Jun 22, 2005 | 03:55 PM
rsjay's Avatar
Actually the harness is out of a 1994 LT1 firebird and the PCM harness is from the same.
Old Jun 22, 2005 | 04:25 PM
Dave89IROC's Avatar
you sure its not out of a 95?
Old Jun 23, 2005 | 05:13 AM
rsjay's Avatar
not postive but when I got it he told me it was out of a 94. But I did buy the PCM harness and front harness together so they should all connect in right? Would it make a difference if it was a 95?
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
