need info on lt4 springs and tunercat
Old Aug 22, 2005 | 06:54 PM
Warlock1313's Avatar
I just got the lt4 complete spring kit, max spring lift is .525" I want to use 1.7rr's with a stock cam is that enough spring?
I am going to get the akm cable and need to know if you just download tunercat or what?
do the akm cables arrive preassembled?
thx
Old Aug 22, 2005 | 07:08 PM
Re: need info on lt4 springs and tunercat
You will be on the edge, if not over with 1.7 rockers, stock lift and those springs.
The Tunercat website has all the info about how to get their product.
Old Aug 22, 2005 | 08:51 PM
I thought max lift w/stock cam and 1.7rr's = .520" or is it 1.6rr's = .520
I downloaded the evaluation copy , I hope there are more parameters to modify with the definition files.
Old Aug 22, 2005 | 09:06 PM
If my calculations are correct, given the lift with stock 1.5 rockers is
.450 in
.460 ex
that would make 1.6
.480 in
.491 ex
and 1.7
.510 in
.521 ex
You might want someone's expert opinion if that is cutting it too close.
Old Aug 22, 2005 | 11:45 PM
who are the experts?
Old Aug 22, 2005 | 11:48 PM
is this the part number GMPP LT4 HOT CAM KIT (P/N 12480002 for everything ??
cam ,1.6rr's, springs and acessories??
Old Aug 23, 2005 | 12:01 AM
blackztpi's Avatar
tunercat is relatively easy to use. get on their website (tunercat.com) and they will have order sheets. for an lt1, you'll need the "tuner" package and then a couple ecm definition files. you can download them straight off their site as soon as you pay for it.
Old Aug 23, 2005 | 11:28 AM
I was messing wiht the evaluation copy , but it seems reather limited (i.e.- trans shift points , gear change settings), is this because I need the definition files??
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
95chwagon
Jan 13, 2015 09:19 PM
