need info on ground wire! w/ pics
Old Dec 31, 2007 | 03:35 PM
rasputin's Avatar
noticed this wire hanging down after my car made some really weird noises when I tried to start it today. where should it go? it is the wire with the bolt through it in the center of the picture, and the second picture is zoomed out for reference.
is my best bet to strip it down and connect it somewhere to the chassis?
Old Dec 31, 2007 | 03:49 PM
BUBBA's Avatar
You might try Sh.box.com and take a look at the wireing harness.JMHO
Old Dec 31, 2007 | 03:50 PM
Green96Z's Avatar
That looks like the grounding lug off the passenger side fenderwell.
Old Dec 31, 2007 | 04:09 PM
greenmachinedriver's Avatar
i think there is a ground running to the passenger motor mount. it looks to be about the right lenght to get to the mount.
hotrod18_69's Avatar
Looks like the batt. cable ground to me.. Most likley the reason for the weird noise.. Car wont like it very much if the ground's not grounded! lol
Old Dec 31, 2007 | 08:44 PM
matLT1's Avatar
If you look at the picture posted by the OP, you can see that these wires are still bolted to the block. The only other ground on this side of the block is the PCM Ground. The wire hanging is the PCM ground and needs to be bolted back to the engine.
Old Dec 31, 2007 | 09:38 PM
SS RRR's Avatar
Old Dec 31, 2007 | 09:51 PM
Ooops you guys are right now that i look closer at the pic..
The only thing left in that area would be the PCM ground. Goes right above the knock sensor.
Good eye guys.. I've been drinkin since 4! lol
Old Jan 1, 2008 | 07:38 PM
rasputin's Avatar
thanks for the help everyone I really appreciate it! I wish I could buy all of you a beer
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
jayvar
Feb 2, 2015 10:00 PM
Injuneer
Dec 15, 2014 09:36 AM
Brandon Wittmer
Dec 3, 2014 09:28 PM
kandied91z
Aug 6, 2002 01:18 AM
