need help with water pump
Old Oct 6, 2003 | 01:09 PM
PumpkinKingZ28's Avatar
my water pump went out, we are having trouble figuring out how exactly to get it off. we had all the bolts out and it still wouldtnt come loose. whats going on??? what am i forgetting? how much does a water pump usually run??? thanks
Old Oct 6, 2003 | 01:18 PM
S.J.S.'s Avatar
A water pump will run you about 50 bucks unless you get an electric one from CSI or something that will run you in the high 150's. You can take all the bolts off the pump but there's a whole bulch of stuff you gotta take off before the pump comes off. Brackets and stuff.
Old Oct 6, 2003 | 01:20 PM
is replacing the waterpump a do your selfer????is very complicated??
Old Oct 6, 2003 | 01:28 PM
S.J.S.'s Avatar
I did mine twice already. It aint hard at all, just time comsuming and frustrating because you have to remove all kinds of other crap just to get to the pump.
Old Oct 6, 2003 | 01:31 PM
joeSS97's Avatar
Not too hard,it takes time.Especially your first time.There are six bolts holding it on.You may have to pry it off.It is siliconed on.Clean the surfaces good.Use gaskets and silicone to reseal it when assembling.
Old Oct 6, 2003 | 01:33 PM
blksunshine's Avatar
Make sure you removed the air pump if you still have it.
Waterpump was the first think that I replaced on my car. I bought a mieziere and it is still going.
Old Oct 6, 2003 | 01:45 PM
S.J.S.'s Avatar
You removed the air pump??? Just got rid of it?
Old Oct 6, 2003 | 01:55 PM
thanks guys hopefully i can do this, im trying to conserve money, this car has sucked enough out of me.
Old Oct 6, 2003 | 02:03 PM
TMD95Z28's Avatar
i did mine yesterday, and its a lot easier if u take off the throttle body, and the coil. To make it easier to take the waterpump off and on (vice versa).
just my 2 cents
Old Oct 6, 2003 | 02:14 PM
also do we have a timing belt or chain??? the blade that is connected to the cam shaft, does it come off with the water pump housing.
Old Oct 6, 2003 | 03:47 PM
jonaddis84's Avatar
Dont exactly know what you are asking, everything is external for the water pump, it is driven by a gear driven off the cam sprocket, but it is all outside the timing cover. After you got the 6 bolts out just pull hard and thats it, clean the surface, slap new gaskets on, put some black RTV around the threads on the bolts and bolt it back on, all there is to it.
Old Oct 6, 2003 | 05:23 PM
RENE95Z's Avatar
Just did mine today, you will need to remove the air pump and the bracket that holds the air pump also. Outside of that, disconnect a bunch of hoses and have at it. Helpful hint, get rid of all the stock clamps and get new ones in case your waterpump takes a dump within the month or so, ask me how I know. It will make doing this job easier the next time around.
Old Oct 7, 2003 | 02:53 PM
TMD95Z28's Avatar
our car have a timing chain not belt. i dunno what belt u r talking about, but dont worry about the timing chain. the water pump is 100% outside of the timing chain cover. just like what jonaddis84 had said.
Old Oct 7, 2003 | 03:03 PM
i appreciate it guys, the last question about the belt and the blade were meant to be seperate questions about the car in general, thats my fault . anyway thanks
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
