need help w/manifold
i have a 94 lt1 and i just bought a 95 intake manifold thinking that they are the same. but i forgot about the optispark thing. what should i do? can i cover the intake manifold port under the throttle body w/ something?? can someone plz help. thank you.
Re: need help w/manifold
As noted above, 94-97 manifolds have ther same ports on them. The port under the throttle body was used for the PCV valve vacuum in the 95 and later engines. Yor 94 manifold has the same hole, but it has a threaded plug in it. As far as the Opti vent vacuum connection, simply "tee" into the EGR vacuum solenoid connection.
Here's my 94. The PCV valve is connected by a U-shaped hose to a fitting behind it. The Opti vent vacuum hose is "tee'd" into the EGR vacuum line. The port under the throttel body has a threaded plug in it, just like my original LT1 intake :
