need help very badly.
90 camaro. <95 lt1/4l60e w/ odb1pcm> the car is doing some crazy stuff. it idles perfect in neutral or park. you put it into any gear and the car miss's like going crazy. like its hitting limp mode. after 30 seconds <timed it> the idle picks up and no more missing. soon as the gas is applied in gear it miss's again. i unplugged the 12/13 plug from the transmission. and the same deal. unplugged the vss. same deal. the car will miss in gear. you can then put it into park or neutral and exactly 30 seconds the idle picks up. you can give it gas and rev it all day in park/neutral and it runs like a champ. but soon as its put into gear it goes down hill. help me please=\ for this is a project car and i havent wired a obd1 port yet. guess ill see if i can find a schematic for it
. thanks in advance
. thanks in advance
