NEED HELP!! Terrible noise from passanger rear wheel!!!
The car was driving fine, then this afternoon when my car (A4) went into second there was a loud THUD (like a pot hole sound) that came from the rear wheel. I thought I hit a hole in the road, then when I came to the next stop light and started to go again, when it went into second it made that same noise. What do you think it could be, shock, spring...????!!!! I have no idea!!! And the thing is I just blew my money on a catback!!!
Thanks for the help.
JOHN
Thanks for the help.JOHN
It is weird though, it is only comming from that back wheel...it is a real terrible sound...I seriously thought that the rear end was going to fall out from under me. What are the symptoms of the tranny mount? Thanks shoebox! P.S. It only happens going from first to second...and it doesn't make a noise going from second to third to fourth...hope that helps.
hey, mine started out making a thud just like that not too long ago. it would only thud going from first to second. then, with time, through second and third as well. now recently i started noticing it when i hit a light pothole. i changed out the shocks and struts, but that didnt fix it. so i'm going to change out the springs tomorrow or thursday, so i'll try and let you know if that helped at all. mine is doing the exact same thing. the noise is coming from the rear end. if that doesnt work, ill go for the tranny mount. ill keep you posted. hope this helps.
dave
dave
Thanks a ton Dave...It would be great if that fixes the problem...Keep me posted. My email is pennys58@hotmail.com. Thanks again. Anyone else with this problem or solution please help us out. Thanks.
JOHN
JOHN
I had this exact same problem, changed shocks, u- joints, pulled the rear end cover. Finally gave up and brought it to a tranny shop. Tranny mount. Cheap and easy fix. Get under the car and push on the tranny you'll see it move.
Thanks Benny Boy and burn rice, I will check it out for sure. I just can't believe that the noise comming from there is the tranny mount(I believe it, but man!!!). I mean, it sounds terrible!! I really apreciate the help...hopefully it is going to be a cheap fix.
Anyone know what it usually costs to have a tranny mount installed including the mount...and is there a certain mount I should get? Thanks everyone
How long can I drive it without damaging the transmission, if it is the tranny mount, is it safe to drive it? I would probably just drive it to the tranny shop. Also, if the mount is broken is it damaging the transmission? Thanks.
JOHN
JOHN
It costs so little for a trans mount, like 30 bucks, whats the point of not fixing it or waiting around? Its been so long I can't even really remember what problems it causes, I got an ES mount and it hasn't caused me any problems and its been a good 2 years.
I think not fixing it can cause problems, but didn't wait and see what. Prolly mess the linkage up after a long while.
Yeah, I plan on fixing it asap...I wasn't planning on waiting around or not fixing it at all..infact I plan on taking it in the morning. I just didn't know if I should really drive it, because of how bad the sound really was. I would get it towed if I were going to really destroy any thing down there. Thanks.
JOHN
JOHN
