Need help with shorter spark plug
Old Jun 1, 2005 | 09:31 PM
valter's Avatar
No way #7 NGK TR55 will fit in place without plug wire - header contact. Please let me know what options do I have for shorter plugs, I really don't want to dent my headers (Hooker super-comp).
Old Jun 1, 2005 | 10:11 PM
Z284thgen's Avatar
Re: Need help with shorter spark plug
my taylor plug wires are really tight as well on the tube its self on #7 with my hooker LT's
and im running a autolite 106 plug
Old Jun 1, 2005 | 10:20 PM
valter's Avatar
That looks perfect; this plug will definitely help me out. Thank you!
Old Jun 1, 2005 | 10:26 PM
Z284thgen's Avatar
are you runnin the otvc kit on yours thats what mine has
Old Jun 2, 2005 | 06:43 AM
whatsup's Avatar
If you want even more clearance get the Accel header plugs. They are a good 1/4"-3/8" shorter than the std plugs. They are pricey and platinum plugs. I had the same issue with #7 and they worked fantastic. Now I'm spraying so I had to bash in the header to get non-platinum's to fit anyway.
Old Jun 2, 2005 | 10:52 AM
valter's Avatar
I am using Taylor's too, but not otvc, #7 run in heat shield bolted to block. Short Accels will be terrific. I'll try to find something today, need to get everything running asap. Thanks!
Old Jun 2, 2005 | 11:17 AM
CreatiVe2's Avatar
i have the taylor wires also, but i used a boot protector, just some insurance for never burning as wire again! its up on my car domain page #3
Old Jun 3, 2005 | 03:24 PM
keng's Avatar
Dude, the spark plug will fit. I had the exact same problem. I put the plug in by hand and got a 5/8 socket 1/2 drive slid it on the plug and used vise grips to turn and tighten the socket. It worked perfectly...
jayblev95
Jun 7, 2015 04:04 PM
markzzzz
May 8, 2015 09:21 AM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
