Need help with screwed motor
Old Feb 16, 2004 | 09:30 PM
BigChief's Avatar
Ok, so the heat guage on my 97z28 apparently was stuck on regular operating temperatures while it overheated, and looks to have at the very least blown a head gasket and/or warped/cracked one or both of the heads.
I first noticed it when the engine would bog under accelleration, and steadily got worse. At first I thought it was the opti, since I've heard all sorts of horror stories. It finally got really bad and wouldn't idle steadily, then started idling at 2000rpm in neutral. I shecked the exhaust and there is a LOT of moisture in it (visible water on the ground behind the car).
So, I'm trying to figure out what to do, and plan for it. Should I just get a whole new motor, or just replace the heads(I'd like to get some better ones anyway)?
I'm just worried that if I only replace the heads the opti might still be messed up, and I'd like to avoid having to pay someone to pull it apart to diagnose it if I don't have to.
Anyway, thanks for the help!
James
Old Feb 16, 2004 | 10:18 PM
Tony Danza's Avatar
i would find out why it happend in the first place before i put any money into it.
Old Feb 16, 2004 | 10:23 PM
EbeZ28's Avatar
Are you SURE it's screwed? Have you checked your oil for water yet? Lots of moisture from your exhaust can a number of things. Could the puddles behind your car have been gas? If you don't find water in your oil, and your not burning coolant/throwing white smoke you might just be a good candidate for being in Opti-Hell (or other electrical problems). Here's hoping
alex5366
Mar 27, 2015 03:30 PM
transam_388
Mar 15, 2015 11:53 AM
Chris Anderson
Jan 27, 2015 08:30 AM
squarehead
Nov 21, 2014 08:02 PM
