need help pulleys
Old Feb 14, 2004 | 10:12 AM
lt1g3n's Avatar
need help pulleys
i am basically getting every single part i need to make the lt1 run in my 83 camaro, so alot of parts i dont know if i need or not or never even knew were there =p.. but i have about 90% of everything.. almost done getting all the parts, i still need the knock sensor, powersteering pulley, and the lt1 a/c delete pulley.. but i saw this on ebay--- does every lt1 have this also
?? do i need this to make everything tight and run properly, does this go on the alternator/p/s bracket tahts on the pass side of motor??
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460067149
Thanks guys!
Old Feb 14, 2004 | 10:16 AM
lt1g3n's Avatar
if anyone has a detailed close up of the engine compartment and how the pulleys are positioned and stuff , id greatly appreciate it, ive never had a 93+ camaro, so i was from scratch , but have come a long way, thnx again
Old Feb 14, 2004 | 11:12 AM
JDBlaze85's Avatar
you definately need that pulley. Thats the one that goes in between the AC pulley(or your AC delete pulley) and the crank pulley. That tensioner on ebay is the pulley that tightens your belt for the LT1 accessories so yeah its a must-have.
It takes (2) 10mm. head bolts and bolts onto the same big bracket as the alternator, P/S, A/C.
Good luck with the 83'
Old Feb 14, 2004 | 04:14 PM
This may or may not help.
That ebay item is the tensioner and new they are only ~$29 wholesale.
Old Feb 14, 2004 | 04:31 PM
lt1g3n's Avatar
now is that power steering pump put on with a 2nd bracket? or just mounted straight on there, i have the pump, and it didnt look like it would mount with out extra hard ware.
Old Feb 14, 2004 | 05:48 PM
The ps pump mounts directly to the bracket by the long bolts shown in my pic. You have to spin the pulley to where the holes in it enable you to pass the bolts through to the pump body.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
