Need help picking cam for new setup>>
Old Mar 13, 2006 | 10:31 AM
mattbailey's Avatar
I am building a new 355 LT1, the block is zero decked, has Mahle -5cc pistons with Scat 6 inch rods. The heads are MTI ported LT1 castings that flow 290/190 @.600. Compressioin shouild be high 11's. The car weights 3640 with me in it. I'm looking to go low 11's NA. The car is mostly driven to the track (less than 5000 miles a year) Help me pick my cam....
Old Mar 13, 2006 | 11:49 AM
sssalah's Avatar
Re: Need help picking cam for new setup>>
Are you looking for a recommendation on an of the shelve cam or you wanna go custom? A nice one is the GM847, but certainly a custom should be better.
Old Mar 13, 2006 | 11:52 AM
blkchevyz's Avatar
get a custom.
theres alot of places you can get them. i had great luck with mine from futral motorsports.
Old Mar 14, 2006 | 08:36 AM
mattbailey's Avatar
Custom or off the shelf. Just need some good examples, who to grind, any info is a great help. thanks
Old Mar 14, 2006 | 02:12 PM
clemsb4c's Avatar
I would try to get in contact with Bret beuer (I think that is his name) he does alot of custom cams for people and they seem to have good luck. Or you could call loyd elliott I believe Brett does cams for him also.
Old Mar 14, 2006 | 05:02 PM
SStrokerAce's Avatar
Matt you can go pretty large with the TH350, the bottom end you have and the 3400+ stall.
Bret
Old Mar 15, 2006 | 08:00 PM
mattbailey's Avatar
Thanks Thomas, hows your new setup doing? Went to the track Saturday still in 12.1's but I pull the wheels now with the new QA1's.
Old Mar 15, 2006 | 08:01 PM
mattbailey's Avatar
Bret
Sent you a pm
Matt
drptop70ss
Mar 26, 2015 01:50 AM
pimpss96
Feb 12, 2015 01:28 PM
95chwagon
Jan 13, 2015 09:19 PM
skittlez87
Dec 29, 2014 03:23 PM
siguy
Nov 27, 2014 10:07 AM
