Need help with Overheating
Old Aug 14, 2008 | 03:17 PM
zman613's Avatar
I just put in a new motor with cc503 cam and ported heads. Now its running hot. I bled the system several times, changed the t-stat(160), I cant find any leaks. The fans are working. Anyone have an idea for me?
Old Aug 14, 2008 | 03:20 PM
z28camaro1090's Avatar
does it just run hot or does it totally overheat to the point were its over 260 degrees?
Old Aug 14, 2008 | 03:25 PM
zman613's Avatar
It will get to 260 if I let it. I does take a little while to get there. I turn it off when it gets to around 235.
Old Aug 15, 2008 | 01:52 PM
zman613's Avatar
Any thoughts on this.
Old Aug 15, 2008 | 03:09 PM
Jazsun's Avatar
Perhaps the waterpump is not churning...Would make sense since it just slowly heats up. Doest anything change when the T-stat opens around 160? Such as does the coolant sensor stay stationary for a few minutes then continue climbing?
Old Aug 15, 2008 | 06:11 PM
zman613's Avatar
yes It does stay stationary then climbs.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
