Need Help With Opti
Old Apr 15, 2004 | 10:20 AM
Jdude540's Avatar
Unhappy Need Help With Opti
Alright, after 115k I think that my opti decided that its time to die on me, so i guess i need to replace it. I just wanted to ask a couple of questions:
1. Where would be the best place that i can get another one and is their anything special i should look for?
2. I'm a decent backyard mechanic and just wanted to know how hard it is to do this?
Any help would be greatly appreciated, thanx for any help
Ohh the car is a 94 T/A M6 if that matters at all.
Old Apr 15, 2004 | 10:40 AM
IDOXLR8's Avatar
TO answer your first question Jason Cromer can probably get it to you the cheapest: 877-726-8295. Remember since your car is a 94 you will need a non-vented style opti.
I think you will have no problems replacing the opti.
Old Apr 15, 2004 | 11:36 AM
94Z28WP's Avatar
Buy the whole unit like said above.
I replaced mine recently and changing it isn't a huge deal... Just takes time to remove everything to get to it... You'll probably need a three jaw puller to get the balancer/pulley off... To keep the balancer from moving when I removed the three bolts, I had to stick a skinny craftsman prybar through one of the openings in the balancer and then rested it on the block... You may have to rotate the engine a little with a wrench so the tabs of the hub are out of the way so you can get the optispark off... Those are the only "issues" I had changing it... You don't have to be a mechanical genius to replace it... If your water pump is original you should change that... It's a good time to change the spark plug wires too since it's easier access at the opti... You shouldn't have any problems.
Old Apr 15, 2004 | 01:00 PM
Mtrhds94Z's Avatar
Since you have an M6, put it in gear to get the 3 balancer bolts broken loose..
Also, be very careful that the spline is properly engaged when putting the new opti on[there's one 'missing tooth' that indexes it]
Old Apr 15, 2004 | 03:46 PM
JasonL's Avatar
Never tried that but I suppose it would work, just be aware the car may try to roll when you do that.
What I usually do is put a second ratchet on the center hub bolt.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
