Need Help!!! Oil Gage Is Stuck
Old May 22, 2005 | 03:16 PM
LT1CST's Avatar
Hey Fbods. OK i need some help. A while ago I pulled off my INtake manifold cuase it was leaking OIL in the back of it. Prior to that My oil pressure gage was working fine. I pulled the intake off RTV'd the intake. Sealed it. Put all the bolts back on. Re Torqued the intake. Turned the KEY.and now my OIL gage Just stays all the way UP and it will not move at all. Its all the way past the 80 mark. ANd it just stays there LIKE its stuck. I replaced the OIL SENDING UNIT. And it still reads in the stuck position. I blew some air in the selioniod and the plug to make sure nothing was in there. And nothing. IT still reads in the on postion. I unscrewed the Sending unit. Started the motor. and OIL came POORING out. So thass an Indication that I have OIL pressure still. So PLEASE HELP. Its making oil pressure. I cant find the STUCK OIL GAGE PROBLEM
CHris
Old May 22, 2005 | 03:24 PM
BLACK LT1's Avatar
Re: Need Help!!! Oil Gage Is Stuck
I would make sure that ALL of the electrical terminals within both the connector and the oil sending unit are CLEAN and STRAIGHT.
Sounds like you may have bent a terminal.
If all of that is OK; just give the top of the dash a good SMACK with your hand and see what happens.
EDIT: also make sure that the replacement oil sending unit is the CORRECT one for your engine.
Old May 22, 2005 | 03:30 PM
LT1CST's Avatar
OK question. Have you personally done that before and seen gages get stuck. AND you BANG your hand on the DASH and that knocks it free?
Dude im gonna **** my paints if this works
Chris
ttt
Old May 22, 2005 | 03:59 PM
LT1CST's Avatar
Ok just tried hitting the top of my dash. ANd it did not work at all. NOTHING. SO now what.
Chris
ttt
Old May 22, 2005 | 04:00 PM
Unplug the sensor and ground the wire. If your gauge still is pegged, the wire may have been broken when you did your intake work.
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
phoenix95
Jan 8, 2015 02:44 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
