need help with my 93 z28
Old Mar 18, 2007 | 08:46 PM
chevytime's Avatar
sup yall I had my 93 z28 for about 6 months and it was all good until december I had to get a new water pump,optispark distributor,ignition module,and a thermostat. I need a new radiator,cylinder heads I think im not sure but can you guy's tell me what are the signs of a brokin cylinder head I think its just the gasket hope so also I got the MSD Blaster GM Coil so do I need the MSD spark plug and the wire sets, and the distributor
thanks for all the help
Old Mar 18, 2007 | 09:43 PM
andremvp13's Avatar
Dude, your ****ed. Just junk it and forget about it.
Old Mar 19, 2007 | 01:17 PM
2000GTP's Avatar
You could always take the heads to a shop and have them inspected for warpage of cracks. If they check out good, put on some new gaskets and button it up.
Old Mar 19, 2007 | 01:28 PM
JooneJune's Avatar
Dude WTF happened? Why did you need to replace all of those parts?
Give us more information, smells, leaks, visual damage under the heads...
Are you saying your cylinder walls are busted? Your heads are jacked up? Or pistons? They are all different parts.
BTW... does the car run?
Old Mar 19, 2007 | 02:03 PM
chevytime's Avatar
joone there are no leaks, smells, there was smoke thats it but thats why im askin i dont know if the heads are jacked up and yes the car run but snice i need a radiator it get's hot to fast and i cant go far also I dont see any visual damage the only thing I know is when i was drive it it made this sound like somethings was broke on the right front side
2000gtp I think its just the gasket but can u tell me the signs of a bad gasket
Old Mar 19, 2007 | 04:55 PM
andremvp13's Avatar
Take pics and post them and a video.
Old Mar 19, 2007 | 05:02 PM
BUBBA's Avatar
First of all get the radiator. It will help you determine other things when the coolant is moving through the engine----but even with the radiator in, do not run that engine if there is no oil pressure or there is knocking. You may have just blown a head gasket because of overheating----if you are lucky. JMHO
Old Mar 19, 2007 | 08:36 PM
andremvp13's Avatar
Bra, you blown a head gasket for sure. I don't know what made you think that you did something else, but it's your gaskets(I know this dude). Go get'em fixed men.
Old Mar 20, 2007 | 02:20 PM
chevytime's Avatar
I check the car today and took the oil cap off and look at the head and it seem good I didnt see any cracks or anything like that but i know for sure now how its gettin hot to fast my radiator is no good its all rusty so ima ge a new one when i get the car fixs and im 70% sure that its the gasket thanks for all the help ill let u know the out come when the car gets fix
Old Mar 20, 2007 | 02:22 PM
2000GTP's Avatar
Your head could have hairline cracks that would be hard to catch by the naked eye.
Old Mar 20, 2007 | 06:28 PM
andremvp13's Avatar
How much you think his heads are going to run him to fix. Go and get that radiator boy. Asap and lets throw it on there.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
