Need Help With Lt1 Oil Pump
Old Nov 23, 2005 | 09:18 AM
formulafirehawk's Avatar
my friends 93 T/A oil pump went out. hes knows nothing on lt1s but is slowly learning. so, me and my cousin are showing him. my question is how much is the oil pump, where to buy it, and how much of a pain is it to change?????
Old Nov 23, 2005 | 09:25 AM
busta9876's Avatar
Re: Need Help With Lt1 Oil Pump
in 93 the oil pump will be the same pump used on nearly all small block chevy engines. By 95 the LT1 used an oil pump with a larger pickup tube, 5/8 instead of 1/2.
you can get a pump from about any parts store, or the GM dealer if you want the real deal.
usually oil pumps dont just "go out" what has led you to belive the oil pump is bad?
Old Nov 23, 2005 | 09:51 AM
theres no oil pumping into the heads. me and my cousin adjusted his rocker arms and noticed that there was no oil pumping out anywhere. he had oil and his oil pressure guage shows it has zero pressure.
Old Nov 23, 2005 | 09:54 AM
jsetzer's Avatar
Could be more than the pump.
The guage is electrical (even back on 93s I think) Use a mechanical one if possible.
With my roller rockers I get very little oil all the way up top. Its plenty, but it doesn't spray it like some vehicles I have worked on.
Old Nov 23, 2005 | 09:57 AM
yeah, everything knocks. he was racing some ss and when he punched it his oil guage went down and started knocking lightly. when he got home he got worse and worse so its been parked for 4 months until he finally called me. what else could it be other than the oil pump. i didnt see any crimps or faulty lines.
Old Nov 23, 2005 | 12:05 PM
sssalah's Avatar
Spun bearings....he needs more than just an oil pump.
Old Nov 23, 2005 | 12:10 PM
Mean Green's Avatar
haha needs a new engine. that knocking is his crankshaft eating up the rod and/or main bearings. hopefully he didn't run the car alot after it started knocking. it may not have destroyed the crankshaft.
that's probably what the crank is gonna look like when he rips it apart.
Old Nov 23, 2005 | 01:59 PM
so its just best to buy an ol' lt1 off ebay or something. man, hes gonna be pissed.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Aug 8, 2002 02:53 PM
Captain Kirk
Jul 26, 2002 06:39 PM
