Need help low 230/236 AI heads dyno results.
Old Mar 30, 2005 | 12:25 PM
  #91
Pasky's Avatar
Re: Need help low 230/236 AI heads dyno results.
Air filter? Could be something as stupid as that. Also your MAF could possibly be reading wrong. Try borrowing Turbo Z's. Check for vacuum leaks as well, those will kill the top end.
Old Mar 30, 2005 | 12:59 PM
  #92
turbo_Z's Avatar
The problem isnt the MAF or a vacuum leak.
I was there when the cam went in and can varify its not off a tooth. So pretty much we are looking at a bad cam or some kind of restriction which IMO really isnt bad looking at the datalog. Something else odd is that my original logs on the dyno before the heads look about like z95m6s.. same air flow and same amount of fuel. Power is just considerably less. So im thinking intake valve opens too late and exhaust valve opens too late if thats even possible....
Old Mar 30, 2005 | 01:02 PM
  #93
Pasky's Avatar
Just might be the cam.
  #94
Z95m6's Avatar
Originally Posted by tireburnin
I'll add my couple of ideas.
Cheap and easy:
Your website lists a borla (w/ electric cutout) and midlenths as your exhaust. That is crappy for performance right there. What are you using for a Y pipe? A fairly cheap mod that should help some...a cutout closer to the merge of the y pipe. I picked up 30rwhp+ from cutouts near the header. The overall setup isn't very condusive to hp, but it would be expensive to replace/upgrade.
If you have comp Rs at 1/4 past they are too tight. Mine are at 1/8 to 1/4 and were too tight. My car stopped pulling at 5700 when it shouldn't have. I'm going to go to 0 lash (maybe just a hair past to keep them a little quite). Lash can have a big effect on powerband and upper RPM stuff. Loosen those up a bit.
Have you double checked your TB is operating correctly? Mine was a PAIN to get even somewhat liveable. It wasn't opening fully and sometimes stuck open. Check that its opening 100% and that the TPS sees it as 100%. (Simple and common sense but easily overlooked).
Sorry to hear your still having problems...once you get it running correctly it will be a beast. Don't give up on it.
The exhaust may not be the best setup but i know it isn't costing me 75+rwhp. I'm running Comp R's. I know it sounds crazy but with the Comp R's in there the car doesn't seem to lope as much so maybe they are too tight now. The TB is opening all the way and i'm running a 58mm tb so it can't be an intake restriction anymore. I'm at college right now so i'm leaning towards checking the lash, compression and fuel pressure. I'm pretty sure the last 2 aren't the problem but then its at least ruled them out. I don't think the MAF is the problem either for the reasons Rich pointed out.
Old Mar 30, 2005 | 01:12 PM
  #95
Kraest's Avatar
Retired
The exhaust should be fine, since you have a Borla (plate wide-open?) and a cutout (basically the same thing). The headers aren't going to cause that much chaos.
Vaccuum leak? Compression test? Something is definetly fishy if the MAF is only pulling 280 gm/sec of air. My 396 pulled around 400ish at WOT @ 6800 rpm.
Do you have a Scanmaster or other device to show real-time values? I bet you could figure out the problem if you saw exactly what was going on while it was going on.
Mike
Old Mar 30, 2005 | 01:16 PM
  #96
Z95m6's Avatar
Mike
I don't have my scanmaster anymore. Turbo_Z has one but what do we look? for and when?
Old Mar 30, 2005 | 01:47 PM
  #97
tireburnin's Avatar
Yeah, I didn't mean to infer that the exhaust was costing you 75rw, but it would be worth 10-15rw. And other than the lash, I was just throwing out things to check.
If you can't track it down and all of your sensors/reading check out...try swaping cams. Maybe a GM847 or something. It isn't far fetched to have a cam ground wrong. It is more common with custom grinds, but who knows. You sure the cam is a 230?
Are all the cylinders firing (primaries hot and such)? Maybe a dead cylinder?
Old Mar 30, 2005 | 01:55 PM
  #98
BlkLT1Z28's Avatar
Yeah if you could get your hands on one of those laser temp sensors it would be cake. That way you could see if all cylinders are firing the same. And if everything checks out ok then try a new cam, the 847 would be good with your heads . And if it works then just keep that one in there. As long as your springs can handle the .598 lift with 1.6's.
Old Mar 30, 2005 | 04:28 PM
  #99
Z95m6's Avatar
I want to leave the cam as a last resort because if my old one is fine i'm not gonna gain much. I would probably go custom grind though. I bought the cam brand new from Thunderracing and the cam card said it was a 230/236 other than that i have no other proof. Call me crazy too but i believe the car timing is to far advanced it starts awfully hard. Very similiar to my 69 stang when the timing is to far advanced. I was told by my motor builder that if the cam was to far advanced it would peak early and drop off ahead of time. It kind of makes me wonder.
Old Mar 30, 2005 | 04:31 PM
  #100
Z95m6's Avatar
Mike
Are you saying i should look into a vaccuum leak or compression test? or are you saying those can't be the problem. Thanks Claude.
Old Mar 30, 2005 | 11:01 PM
  #101
turbo_Z's Avatar
There is no vacuum leak.
Old Mar 30, 2005 | 11:18 PM
  #102
TCAL95Z's Avatar
to be down as much power as you are it probably is a combination of things but if your car is starting hard there is a reason. I believe you said you were gettng knock retard too.
If your car isn't using oil then I doubt you have a compression problem.
I think you have a cam/ valvetrain problem and tune.
Since you have knock and your car is not reving to where it should I would start with re-adjusting your rockers and a fuel pressure test.
If fuel is ok and the rocker adjustment doesn't help you've got to degree the cam. Also isn't there a model number or something stamped on the end that you could verify?
We had a guy in AZ who was off one tooth on the cam install and he lost over 50rwhp. In know you say this was verified but the cam could be ground wrong or it could be the wrong cam.
Old Mar 30, 2005 | 11:24 PM
  #103
SStrokerAce's Avatar
I would do a compression test and degree in the cam, make sure the mechanical things are right first.... then look at fuel and spark, those are the next too things.
Bret
Old Mar 30, 2005 | 11:28 PM
  #104
Z95m6's Avatar
Bret
Ok thanks this seems like the plan of action. I see Jeff earlier said its ok to drill the cam sprocket out and putting in a bushing but i've read on here its not ok. Anyone know for sure.
Old Mar 30, 2005 | 11:30 PM
  #105
turbo_Z's Avatar
Bret
So what do you think is my problem, Bret? Bolted on LE heads and switched to LT headers and didnt gain a single measly horsepower. Thing isnt breathing right and am only pulling in ~318 gps at 6k. Tomorrow im gonna set the valves with 1/2 turn past 0 lash to see if maybe im losing lift. Claude(z95m6) said its unlikely since the oil keeps pressure on the pushrod at all times but I have no other ideas.
Heres a run down of what I have. comp cam, comp pushrods(OEM length), comp 987 springs, comp NSA pro mags and stock lifters.
