Need Help Loud Noise!!!
Old Sep 5, 2007 | 01:51 AM
AllenK93's Avatar
sounds like its from the tranny, at idle its fine, revving is fine, in gear and accelerating it makes a loud banging like two pieces of metal hitting together. the banging goes faster and faster as i go higher speeds. the
RPM doesnt seem to make it louder only the speed i travel. if im driving 60 with clutch in no sound, slowing down in gear with clutch out no sound, only while accelerating, what could this be??
Old Sep 5, 2007 | 01:20 PM
AllenK93's Avatar
noone want to help or what?? just don't know.....thinking U-Joint or Rear end now tho....
Old Sep 5, 2007 | 01:28 PM
White96Z28's Avatar
The bang is usually a bad tranny mount, but normally doesn't repeat itself. It will bang on the floorboard once and doesn't do it again until you stomp on it again. Have a look at the driveshaft and make sure nothing is wrapped around it.
Old Sep 5, 2007 | 01:32 PM
Z28SORR's Avatar
Check you U-joints first, then start looking at all the bushing for excessive ware. Pariticularly things that are effected by torque. Engine mounts, trans. mount, torque arm bushing, lower control arms, etc.
autoxr166
Sep 25, 2015 04:21 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
