need help guys
looking at buying a a4 95 z28 no exhaust at no o2 sensores plugged in or egr fire up the car and it starts up the sputters and dies i kbnow havin no egr or o2's on its can cause this but is there nething else serious i should look for
Re: need help guys
the car should start with out o2's and egr. When you first start it it, it will be in open loop. If it notices anything missing like o2s, it will go into limp mode, but it should still start. By no egr do you mean that the tube from the exhaust manifold to the intake is missing or disconnected? if so, that would cause a HUGE vaccum leak. large enough for it not to run.
carguy0119
Apr 11, 2016 11:11 PM
mspennyhughes
Nov 28, 2014 03:22 PM
