Need Help Fast!
Old Aug 21, 2004 | 08:30 PM
Toker420's Avatar
Need Help Fast!
Got all connecions connected car turns over get fuel and spark but does not run how is this possible? What could it be?
Old Aug 21, 2004 | 08:35 PM
Toker420's Avatar
Re: Need Help Fast!
ttt
Old Aug 21, 2004 | 08:37 PM
97WS6SCharged's Avatar
Re: Need Help Fast!
What kind of changes did you make?
Old Aug 21, 2004 | 08:42 PM
Toker420's Avatar
Re: Need Help Fast!
383 short block, trick flow heads, 54mm tb, 30lb injectors, pcmforless.com tunning , hooker lt.
Old Aug 21, 2004 | 08:53 PM
Toker420's Avatar
Re: Need Help Fast!
ttt
Old Aug 21, 2004 | 09:30 PM
Re: Need Help Fast!
Are all the plug wires in the correct places? Did you make sure the opti was installed correctly?
Old Aug 22, 2004 | 12:54 AM
Toker420's Avatar
Re: Need Help Fast!
ya went over the wires twice and also checked to see if the timeing was on to. I took the valve cover off and noticed that the rocker arms were cracked from me over tightening the lash. I took them all off i now need new studs. What did i do wrong i tightened them till them quit spining and then 1 full turned them like the book said and also in the sequence that it said?
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
