need help fast!
Old May 22, 2004 | 08:01 PM
Got-LT1's Avatar
Exclamation need help fast!
What the hell size are the bolts holding the water line on the back of the heads?????
I've tried 14mm 15mm 5/8 9/16 and they are two small or big.
It seems like it should be between 14mm and 15mm but I can't tell and don't want to run the risk of rounding them off.
Old May 22, 2004 | 08:02 PM
Dave Feerst's Avatar
I used 15mm, but I did round one off, had to order a new one from GM parts direct....
Old May 24, 2004 | 12:08 PM
Got-LT1's Avatar
anyone else?
Old May 24, 2004 | 01:09 PM
scoobysnax83's Avatar
It is 15mm, but you need to use a closed end wrench on it. They're a pain, but not impossible... A whole new system came be bought from the dealer for about $30 that replaces the two bolts and lines all the way to the radiator cap.
Old May 24, 2004 | 02:45 PM
Use a 15mm, 6 point tool.
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
