Need help fast!
Old May 20, 2004 | 01:00 AM
hsyr's Avatar
Exclamation Need help fast!
Ok so I blew up my driveshaft a week ago and it took the yoke with it. I got a new yoke and when I removed the nut (1 1/4) from the pinion I never marked it or anything. Pulled the old yoke, put the new one in with the old seal and tightened it as far as it would go. Now that I've read this site and a couple of manuals I realize I've tightened the pinion nut wayyyyy tooooo tight
How exactly do I got about getting in on far enough but not too far? I did a search but came up with nothing. Help!
*EDIT*
I've only put about 15-20miles on the rear since I did this and it isn't making any noises and also, does anyone remember how many threads were sticking out on their 10bolts by chance or how far you measured before you took off the pinion nut? I would imagine its the same for all fbody 10bolt rears. Anyone know?
Old May 20, 2004 | 05:44 AM
slopokrodrigez's Avatar
Your concerned with the drag on the bearing when the pinion nut is tight. Here this should help.
http://www.corvettefever.com/howto/36479/index.html
2 questions, When will you tell us what hsyr means?
What is with the obsession with 87camracer????
Old May 20, 2004 | 07:01 PM
hsyr's Avatar
Ok I read that and I'am still confused. I've read posts on here where dealerships tightened the pinion nut too much and it ruined the rear because of too much pressure on the bearings. But yet in that guide they use an impact to tighten down the nut Am I supposed to tighten the nut until the yoke is tight with the bearing and then tighten the hell out of the nut with the impact or what? Can anyone clairfy for me? I would like to drive my car this weekend without fear of ruining the rearend.
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
