need help with exhuast setup
Which company sells a catted y pipe that will fit either jet hot or pacesetter lts and works with the slp loudmouth? I hate being new at this stuff
will the tsp catted y pipe for the ls1's work for my 94 lt1?
will the tsp catted y pipe for the ls1's work for my 94 lt1?Thanks
Re: need help with exhuast setup
Unfortunately the y-pipes that come with the long tubes are called off-road y-pipes for a reason. I just installed Pacesetter LTs and the ORY pipe and I am in the process of modifying the y-pipe to accomodate cats. You might have to go down the same road if you want to maintain a cat. with your future header install.
I am not good with emisions questions since I have never had to put any of my cars on a treadmill before, but if they do visual inspection where ever you live it will not pass. I would think that a stock engine without CATS would be close, but you could pass IMO.
detroitmuscle
Jul 31, 2015 04:21 AM
