Need help/EGR advise!
Old May 14, 2005 | 02:45 PM
fredmr39's Avatar
Exclamation Need help/EGR advise!
Hey guys
So I got my car scanned to see what code I was throwing and it was in regards to EGR flow. I'm almost positive that its the connection form the flex tube to the headers, because it isn't exactly perfect. Any tips to getting a better seal? I thought I had the flex tube bent at the best angle, but apparently not. Also, I was just thinking - I cant remember if I used any RTV - should I try using some of that as well? Thanks!
Old May 14, 2005 | 03:07 PM
fredmr39's Avatar
Re: Need help/EGR advise!
So I guess my main question is - CAN I use RTV to aid in sealing the connection on my headers?
Old May 14, 2005 | 03:09 PM
Z06Z28's Avatar
the tube at the headers I just bolted it up really good and left it alone. Whatever sealant you use, make sure that it's 02 sensor safe.
Old May 14, 2005 | 03:11 PM
fredmr39's Avatar
I might as well try a tad on the side w/o the bolt, that's the side that didn't look so tight. I'll bend the crap outta it some more and use some O2 safe RTV. Thanks for the response!
93 RedBird
Nov 15, 2015 08:24 AM
drt
Sep 27, 2015 04:39 PM
canuck94z28
Aug 19, 2015 05:50 PM
chuyz28
Jan 27, 2015 08:53 AM
91RS_Rider
Oct 20, 2002 10:49 PM
