Need help diagnosing no start/dieing scenario.
Old Apr 4, 2006 | 07:08 PM
raxxus's Avatar
Angry Need help diagnosing no start/dieing scenario.
I have a 95 LT1 with long tube headers. The car runs fine, then will die and will not start. After sitting, it'll start right up fine, until it dies again. I went outside to check for spark on a no start, and found the wire loom running down the passenger side was well burned into by the header ( it broke loose from where I had it ). Its the bigger wire loom, not the smaller one ( which is for the O2 sensor anyways). Anyone know what those wires run to? They are burned into pretty damn bad!
Old Apr 5, 2006 | 03:39 PM
93transam1234's Avatar
Re: Need help diagnosing no start/dieing scenario.
do a search for shoebox site i think he has some wireing diagrams.
BTW i would say just buy a whole new wirring harness and make sure to tie them out of the way of those headers!
Old Apr 5, 2006 | 03:47 PM
SoloExceptional's Avatar
Mine got burnt through too, and if I remember correctly, the wires in that loom were for the O2's, Knock Sensor, and either a ground or starter wire, I can't remember, I had to extend my wires out wrap them back up and move them outta the way permently
Old Apr 5, 2006 | 03:58 PM
i wouldnt suggest exstending the 02 sensor wire if you dont have to, they are very very sesative and from what i have heard splicing them makes them malfunction.
Old Apr 5, 2006 | 05:41 PM
snakeatinZ's Avatar
find a write up on how to do this. Cut the wires before the burn and splice longer wires on them, run them along the ac / heater core lines (zip ties) down above the ac compresor to relocate them. You will never have this problem agian.
Steve
Old Apr 7, 2006 | 01:31 AM
raxxus's Avatar
Thumbs up Re: Need help diagnosing no start/dieing scenario.
Thanks guys for the quick responses! I'll be working on it this weekend, and hopefully that'll solve my problems! Much appreciated
jbert55
Oct 31, 2015 03:52 PM
Aug 24, 2015 06:41 AM
Aug 17, 2015 09:50 AM
techstar
Aug 6, 2015 11:20 AM
ad356
Apr 11, 2015 11:12 PM
