need help with deleting EGR, and AIR
Old May 22, 2004 | 01:05 AM
BlackbirdWS6's Avatar
Im doing a heads/cam/headers install on my 97 TA. I will be deleting the cats and would also like to get rid of the EGR and AIR. What do i need to plug up the stuff it hooks up to? i am having my computer reprogrammed at Fastchips and told them to delete the air, egr, and rear O2's. any help would be greatly appreciated.
- Brian
Old May 22, 2004 | 01:39 AM
carlos64030's Avatar
I purchased my block off plates from here.
Old May 22, 2004 | 01:46 AM
97WS6SCharged's Avatar
GM also made a block off plate for the LT4 cars that works on the LT1. It's quite a bit less than those billet pieces that no one will ever see.
Old May 22, 2004 | 02:40 PM
how about the AIR? how do i plug that up? also, what parts other than those billet pieces can I go with? thanks
Old May 22, 2004 | 02:44 PM
joeSS97's Avatar
Its pretty easy to make up block off plates.Get a 1/8"thick piece of aluminum.
Old May 22, 2004 | 02:52 PM
RamAir95TA's Avatar
For the AIR blockoff, you'll need two M18 plugs for the holes left in the manifolds/headers, and a 5/8" vacuum cap to plug the hole left in the intake ducting. You'll also need programming to clear the SES light that will follow.
Do you plan on passing the sniffer with !AIR and !EGR? Not in NJ I hope...
Old May 22, 2004 | 05:24 PM
heh well i got a buddy....and also a year till i have to be inspected. I am going hooker long tubes, so i dont need the manifold caps. anyone know what part numbers are for the plates to block off the EGR rather than those billet pieces? thanks
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
k1996z28
Jan 21, 2015 07:22 AM
97SSdude
Dec 31, 2014 07:43 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
