need help with a/c and fans
Old Mar 30, 2004 | 02:59 PM
logo20's Avatar
Hi,
I'm new to the forum and i'm already having problems with my car. I have a 94 z28. the ac and fans don't work. one of the fans was wired to stay on all the time. I checked the fuse and they're ok, then used a test light and there is no power to the fuse all the other fuses and relays are getting power. the ac/ and fan fuses uses the same wire, it's an orage wire. does anybody know where this wire come from? maybe ignition switch? I'm gonna go buy a switch for the fan, but it's getting really hot! and i want ac. also check engine light is on. I'll appreciate any help.
thanks,
Old Mar 30, 2004 | 03:34 PM
Give the fuse number you are saying has no power. I don't see where the a/c and fans are on the same fuse.
Old Mar 30, 2004 | 03:46 PM
logo20's Avatar
under the hood is #5 and #6. the turn signal is not working and in the fuse box #2 is not working. I haven't checked all all the fuses inside the car, but the are probably more without working.
Old Mar 30, 2004 | 04:03 PM
HBHRacing's Avatar
did you have the key on when you tested for hot at the fuse? The AC/cruise fuse is nly hot in run and start, heater/ac fuse is hot in run as with the fans fuse. did you acualy remove the fuses to look at the concetion the termonals are making?
Old Mar 30, 2004 | 04:30 PM
logo20's Avatar
all the testing was done with the ignition key on, not running. i did look under the fuse box and the conection is good. so inside the car number 2 and 3 don't work and under the hood 5 and 6 don't work. that's abs, fans, ac and turn signals.
Old Mar 30, 2004 | 04:42 PM
Those feed off the ignition switch. That's where I would go next. Look for the orange wire in the black connector. Possible that your ignition switch could be bad, too.
Old Mar 30, 2004 | 09:55 PM
logo20's Avatar
thanks shoebox, the ignition switch is burnt pretty bad i hope that's the only problem.
later,
Old Mar 30, 2004 | 09:59 PM
later,
Pretty common. There is a replacement guide on my Tech Page if you need it.
Old Mar 30, 2004 | 10:01 PM
logo20's Avatar
i know, i used it, still taking it out was a bitch
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
Pwilson59
Sep 3, 2015 08:47 PM
