Need Help Bad
Old Jan 28, 2005 | 03:25 PM
Z28Horn's Avatar
Need Help Bad
I have both my exhaust manifolds completley unbolted and the passanger side gets caught on the cat and crossmember, not to big of a deal, i will chop that w/ a sawzall, but the passanger side i took outh the hard line going into the back of the manifold, I cant get the damn thing out of there, any suggestions, and the other question is where do i get a block off plate for the back of my manifold, i wanted to have everything out today but i got a snag, thanks guys, your help is greatly appreciated.
Zach.
__________________
Alcohol, the cause and solution to all of lifes problems.
1996 Camaro Z28 195,000 mi.
K&n, Tb bypass, ported and polished maf, Trick flow elbow, Pacesetter Longtubes, 3" offroad y-pipe, strut tower brace, LCA's,Magnaflow catback, soon to have 3:73 gears and stall
Old Jan 30, 2005 | 06:38 AM
slopokrodrigez's Avatar
Re: Need Help Bad
Cut the line off if you plan on blocking it any way. Contact these folks for blocking plates.
http://www.mycamaroz28.homestead.com/
colts0455
13
Aug 7, 2015 09:15 PM
Jocofire1
Aug 7, 2015 03:16 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 8, 2015 12:21 AM
colts0455
Jul 7, 2015 07:19 PM
