Need help ASAP! What size tap for header bolts!?!
Old Apr 12, 2003 | 11:40 AM
94 CAMRO Z28's Avatar
Unhappy Need help ASAP! What size tap for header bolts!?!
Heads and intake are all back on, and now im putting the headers back on. I have one bolt that doesn't want to go in without cross threading, and then the bolt that holds the support for the alt. doesn't want to go in because the fel pro gasket covers part of the hole! So I figure I'll tap both the holes and see what happens. Thanks
Aaron
Old Apr 12, 2003 | 12:46 PM
joeSS97's Avatar
Take the bolt with you to an auto parts store and watch it up.
Old Apr 12, 2003 | 01:19 PM
blown383's Avatar
You don't need that last bolt to support the alternator....so you can go without it.
-B
Old Apr 12, 2003 | 01:26 PM
-B
Ok thanks, I looked at it closer and decided 3 or the 4 bolts for the alternator should be plenty to hold it solid. That'll save me some time and $$.. Thanks again guys.
Aaron
Old Apr 12, 2003 | 01:38 PM
Rodrigues's Avatar
That bracket hooks to the exhausts? I was trying to figure out why I had a leftover alternator bracket after the header swap! lol...
Old Apr 12, 2003 | 01:50 PM
LOL, yea the very front bolt on the passenger side gets screwed in, and then there is a support that goes on that along with another nut to hold the support on.
Aaron
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
