Need Help ASAP Exhaust
Old Jan 29, 2004 | 09:07 PM
WhiteBeast's Avatar
Exclamation Need Help ASAP Exhaust
Ok, I have all the bolts off that old the passenger side exhaust manifold on and all I have is the stupid EGR pipe holding it on. But I stripped the nut that holds it to the manifold.
So what do i do now?
How do i remove the Automatic Transmission Fill Tube?
Old Jan 29, 2004 | 10:02 PM
ibanez6rg's Avatar
Unbolt the other end that connects to the intake.
Pass. side, 2 bolts.
Old Jan 29, 2004 | 10:15 PM
Spinner's Avatar
What he said. Then grind/dremel the bolt into two pieces. it'll let go
Old Jan 29, 2004 | 10:30 PM
WhiteBeast's Avatar
Ok, I unbolted the EGR Pipe all together. And pulled out the transmission fill tube. The EGR pipe just wouldnt fit through any passage so i ended up taking a chisel to it.
I know I know, Why in the hell did i break it. Well I have been working at it for 7 hours and I got tired.
NOW my question is how can i fix this or where can i find a replacement?
Old Jan 29, 2004 | 10:35 PM
ibanez6rg's Avatar
If you need another EGR pipe, you can have mine for shipping.
Old Jan 30, 2004 | 12:04 AM
WhiteBeast's Avatar
I sent you an email.
Heathen1
Jan 2, 2016 04:27 PM
james4154
Jun 15, 2015 12:16 PM
May 15, 2015 10:43 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
Brake_L8
Jan 20, 2015 09:44 AM
