Need Help Asap
Old Apr 4, 2004 | 02:30 PM
Allwaysbroke Z's Avatar
Angry Need Help Asap
Trying to get the opti off and i cant figure out how to get the bottom screw off... i have it undone but there isnt enough clearence between the opti and the pulley directly in front of it.. and the screw is too long to pull out.. its hitting the pulley.. how the hell do i get this screw out???????????
Old Apr 4, 2004 | 02:40 PM
sc93's Avatar
Why don't you just take the pulley off?
Old Apr 4, 2004 | 02:41 PM
well i tried that... put a torque wrench on it but all it does is turn the pulley.. that and i think the pulley might be pressed on which would make it near impossible to take off
Old Apr 4, 2004 | 02:45 PM
sc93's Avatar
Yeah, you may need to go to AutoZone and rent a 3 jaw pulley puller to yank it off after you remove the 3 bolts. That's what I had to do
Old Apr 4, 2004 | 02:49 PM
Hawk's Avatar
nice username, is your Z always broke,
Hope you get it running soon, it's better when you get to drive them.
Old Apr 4, 2004 | 02:50 PM
Daryn95Z's Avatar
Put your transmission into gear, then try and loosen the bolts.
You will have to most likely rent a puller from a parts store to get the pulley off.
You HAVE TO take the pulley off to get the opti off!
Devinfoote87
Sep 4, 2015 05:52 PM
asilomar244
Jul 12, 2015 05:53 AM
james4154
Jun 15, 2015 12:16 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
