need help 95 z28
Old Aug 23, 2006 | 01:24 PM
speedy1546428's Avatar
need help 95 z28
Im having a problem with a 95 chevy camaro z28
i recently installed taylor 8mm spyro wires and ngk tr55 plugs. the reason for this was i am getting spark at the plug boots itself on #8,#4 #3 and around my coil . i replaced my cap and rotor too with an accel from summit. what would be causing this i tried 4 different sets of wires and changed the coil too no difference . cleaned the boots and used dielectric grease and cleaned and checked all grounds it still does the same. is this common or did you ever hear of this and what else could i check
thank you for any help
speedy!:
Old Aug 23, 2006 | 04:02 PM
OBE1 95Z28's Avatar
Re: need help 95 z28
Check that the grounds to the engine block are clean and tight.
Old Aug 23, 2006 | 05:38 PM
1racerdude's Avatar
If it is just a "halo" it is called a "corona". Go to NGK's site and get the straight scoop about it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Renegade Toker
Jan 23, 2015 10:27 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
