Need help with 700R4 conversion
Old May 29, 2004 | 03:28 AM
Lt1tko5o's Avatar
I put a 700R4 in my friends corvette due do 1-2 shift problems.
Has anyone done this with the OBD1's?
I tried loading a M6 program in the computer so the comp wouldn't look for the 4l60E, but with the manual program loaded, the engine won't stay running, it starts, then stalls after 5 seconds.
Thanks for any help
Brian
Old May 29, 2004 | 03:44 AM
97WS6SCharged's Avatar
The engine won't stay running at all or it won't stay running when it's put into gear?
Old May 29, 2004 | 03:58 AM
Lt1tko5o's Avatar
The engine won't stay running at all, doesn't matter if you give it throttle, it's like the comp shuts it down.
Brian
Old May 29, 2004 | 04:00 AM
Lt1tko5o's Avatar
By the way, we're from Jax originally, I've known Brent Frazier for about 10 years.
Brian
Old May 29, 2004 | 04:09 AM
Nice. Yeah, Brent is a great guy. He seems to think every car he touches should be a race car though.
Interesting. Are you using the same computer with a different load or a completely different computer?
Old May 29, 2004 | 10:03 AM
dkeers's Avatar
I swapped a 700r4 into my car. Ion @ madz28.com did my tuning via e-mail. He made a lot of changes for the cam, and emissions etc.. As far as I know, the only change he made regarding the tranismission was installing a program from an M6 car. Maybe you could try to e-mail him to see if there were any other changes that had to be made.
Dustin
Old May 29, 2004 | 11:09 AM
96capricemgr's Avatar
I think IAC values from an A4 car might help, I know when going from an A4 to a t56 this is something that needs to be addressed.
Old May 29, 2004 | 10:07 PM
IrocSS85's Avatar
I did that swap. orig, when I finished instaling it, I had the stock tune. all was just fine exc. the speedo was WAY off. like it said 100mph whle I was really goin around 45 on the way to work. I had to get a custom tune and install an a4 tune, but delete all the functions/codes of the trans. the speedo gears in the trans are totally diff between the two. the t56 had like 20 teeth, and the 700r4 has like 10 teeth. I dont remember what the teeth count really are, but you get the idea. the speedo calibration was the only reason I needed the a4 tune. Im sure the idle tables are in there for an a4, but it idled/ran perfect for the few days I drove it after the swap, and before the tune.
RUENUF
Mar 13, 2016 03:37 PM
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
tdigger9899
Sep 7, 2015 10:56 AM
Cam's maro
Aug 11, 2015 07:45 AM
