Need Help!
Old Feb 29, 2004 | 02:32 PM
fstenuf's Avatar
Need Help!
ok guys idk what the deal is...when i got my car out after the winter went for a lil drive then pulled it in my driveway and it made a clickin noise almost as if there was two metal parts hitting together...but then i let it sit there for a while and went away...and didn't hear it until a week later...and now its hesitant when i try to accelerate also and when i try to stop it wants to die on me if i don't keep the revs up...
also when i pushed in the clutch it made the clickin noise again...but it i kept the revs up it ran fine...like between 2500 and 3500rpms...idk what the deal is because the motor, tranny, clutch and everything has less then 10K miles on it...i haven't had the valves adjusted yet this year so idk if thats the deal or what...maybe the timing is off...it could also be a bent lifter but idk why that would go away for a week then come back. the guy i bought the car from is sending me the cam card so i can adjust the valves if that maybe the problem. any info would be greatly appreciated..
Old Feb 29, 2004 | 02:36 PM
kmook's Avatar
Advanced Tech Moderator
General troubleshooting should be discussed in a General Tech forum. Transfering to LT1 Tech, thanks.
Old Feb 29, 2004 | 03:49 PM
fstenuf's Avatar
TTT
