need help
need help
i test drove a 94 camaro that i might buy today and it was awesome, but the only problem is at very slow speeds when i hit the gas it wouldnt really excelerate. mebbe i was just not hitting the gas enuff. afterall it wasnt my car so i was driving extra carefully. either that or something is wrong. what could it be if anything.
In my first act as a Moderator I am going to try to move this thread to "LT1 Tech" where I think you will be more likely to find an answer. This forum is for driveline issues (clutch, tranny, DS, rearend, etc.).
Good luck with your problem.
Rich Krause
Rich Krause
TPS
This sounds like a throttle position sensor problem to me. you can check it with a multimeter im pretty sure, but i dont know the values that you would be looking for. Thats my initial feeling on the problem, maybe someone with a little more experience will chime in here.
CR
CR
