Need a gasket set list
Old Jun 3, 2003 | 12:25 AM
Timberwolf's Avatar
doing heads/cam/headers.
I need a set of gaskets for the project. I was at a site not long ago and saw a set comprised mainly of GM gaskets, but it was $189. I don't recall which site it was though.
Is there a better priced set? Maybe felpro? Anyone have a list of gakets and fel-pro part numbers? Maybe a vendor that sells them?
I need these ASAP, so any help is MUCH appreciated
Old Jun 3, 2003 | 12:40 AM
thewinner's Avatar
1406 header gaskets
collector gaskets
1074 head gaskets
wp drive seal
opti seal
crank seal
wp gaskets
timing cover gasket
intake gaskets (get felpro)
TB gasket
egr gaskets
thats about all i can think of
sorry about the missing p/n for most of them hehe
Old Jun 3, 2003 | 01:45 AM
QCKZ28's Avatar
thunderracing sell the complete kit
2 banjo bolts
4 seals for the banjo bolts
2 valve covers gaskets (if you dont want to reuse your old ones)
maybe an oil pan gasket, if you rip yours like i did
oh and dont forget about the head gaskets!!! i used the impy gaskets to gain a little compression.
you really should consider going to an electric water pump, you can forget about the water pump seal on the cover and use a double roller timing set. you should be able to get most of the gaskets/seals at your local auto parts store, felpro-timing cover kit, intake, headers. i got a combo of GM/felpro gaskets and it cost me over $150. im in the middle of putting my car back together im doing heads/cam also.
Jan 23, 2015 01:13 PM
Jazsun
Dec 29, 2014 12:14 PM
Brandon Wittmer
Dec 8, 2014 07:53 PM
