neED A GASKET SEAL PART NUMBER
Old Mar 27, 2006 | 09:28 AM
jkucz31's Avatar
i NEED A PART NUMBER FOR THE OPTI-SPARK SEAL TO THE TIMING COVER THANK YOU
Old Mar 27, 2006 | 09:31 AM
jsetzer's Avatar
Re: neED A GASKET SEAL PART NUMBER
The little o-rings around the drive?
I know those come in the felpro timing cover set, along with the water pump gaskets too.
Old Mar 27, 2006 | 10:29 AM
jkucz31's Avatar
Its not the Little copper looking o rings are they, because i thought those were for somthing else
Old Mar 27, 2006 | 10:35 AM
jsetzer's Avatar
I think mine were just black rubber.
But we are talking about the two that go on the opti shaft??
Old Mar 27, 2006 | 11:16 AM
jkucz31's Avatar
hmmmmmmm. does it make a difference that this is for a 94 non vented setup
Old Mar 27, 2006 | 11:23 AM
jsetzer's Avatar
Hmmm Maybe so, I have never seen a non vented.
Hopefully someone else will chime in.
Old Mar 27, 2006 | 12:18 PM
jkucz31's Avatar
Still Need A Part Number What One Is Right This Is The One From Jason Chromer- 12552428
Local Chevy Dealer - 10128317
Old Mar 27, 2006 | 12:38 PM
Mtrhds94Z's Avatar
Why would there be a fdifference? Cromer is a GM dealer parts guy..
I checked and the GM p/n's you list are:
12552428 95-7 opti timing cover seal
10128317 93-4 opti timing cover seal
Old Mar 27, 2006 | 12:47 PM
hsyr's Avatar
FWIW if you mean that 2 or 3" rubber O-ring that goes over the backside of the opti into the timing cover my opti that I removed for the first time never even came with one. Although the non-vented opti I bought in replacement did. Weird I thought
Old Mar 27, 2006 | 12:54 PM
Mtrhds94Z's Avatar
Unvented opti has no 'o'ring' behind the housing?
Old Mar 27, 2006 | 01:18 PM
jkucz31's Avatar
I have a 1994. is the size in the seal a difference. I put the seal from chromer in it and it leaked..... so im going home to try the one for my year. weird huh
Old Mar 27, 2006 | 03:55 PM
Stoopalini's Avatar
Are you talking about the o-rings on the shaft, or are you talking about the seal which presses into the timing chain cover?
You can get a timing cover gasket kit from Advance Auto or Autozone for ~$15. This is a felpro kit which has 2 o-rings, all 3 seals which press into the timing cover (water pump drive, opti drive, balancer hub), the timing cover to block gasket, and waterpump gaskets.
Thomas.
Old Mar 27, 2006 | 05:30 PM
jkucz31's Avatar
Thomas.
where do the o rings go right on both sides of the shaft. which would make it a double gasket idea because it goes into the seal on the timing cover
Old Mar 27, 2006 | 05:54 PM
Stoopalini's Avatar
I don't understand your question (if you asked one?)
Here is a diagram of the timing cover and Here is a diagram of the opti spark (both compliments of Shoebox).
Notice the two different timing chain covers on the bottom of the 1st picture. The '93-'94 definitely has a smaller opti drive seal.
So again, which seal are you asking about (o-rings or seal in the timing cover)? Like I stated earlier, all these seals can be purchased in a kit from your local autoparts store for $15.
Thomas.
Old Mar 27, 2006 | 06:04 PM
jkucz31's Avatar
ok well i got the gasket and i need to know where the 2 little o rings go.do the go on both ends of the opti spline drive or what
