need electrical help please!!!!!!!!!!!
Old Mar 5, 2004 | 04:46 PM
maddog89's Avatar
i keep blowing the 10 amp fuse under the hood for the coolant fans? any ideas? could it be a relay possibly? thanks for any help
Old Mar 5, 2004 | 07:15 PM
The owner's manual says it powers these things:
Fuse 6 - Coolant Fan Relays; EVAP
Canister Purge Solenoid; Exhaust
Gas Recirculation; Low Coolant
Relay; Reverse Lockout Solenoid
( 10 Amp.)
Your problem could be in any one of those items. If it only blows when the fans try to come on, then it might be a faulty relay. If it blows as soon as you turn the key ON, then try unplugging those items until it does not blow. If everything is unplugged and it still blows, you probably have wire grounded out that you will have to find.
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
