need a balances rotating assembly
Old Oct 16, 2011 | 04:49 PM
dennis5374's Avatar
I've been searching for a balanced rotating assembly all afternoon. Im looking for an eagle 4340 crank,eagle h beam 5.7 rods, and a good set of forged pistons. I wanna stay around. 11/12 to 1 compression ratio. I also wanna be able to lower compression in case I want too add a blower or turbo in the future. I searched ebay but can't find a balanced kit anywhere with forged pistons. I wouldn't mind doing a 383/385 either. Im looking too spend under 2k if that's possible. Thanks in advance
Old Oct 19, 2011 | 03:35 PM
Mystery Bird's Avatar
Re: need a balances rotating assembly
I"ve been looking at Ohio, they have one that is ready to install, so they say. I imagine they could do it for any one of their kits though.
http://www.ohiocrank.com/chevsb_rotate.html
Old Oct 19, 2011 | 03:39 PM
RamAir95TA's Avatar
FWIW I have an Ohio crank in my engine.
Old Oct 19, 2011 | 03:54 PM
I picked up a prepped block and will probably be buying one of their ready to go kits. RamAir How was customer service?
Old Oct 19, 2011 | 03:59 PM
RamAir95TA's Avatar
To be honest my builder recommended them and while I was skeptical at first apparently he uses them in all of his engines. Must be good enough.
Old Oct 19, 2011 | 04:01 PM
Now that I think of it I pretty sure I read in one of your posts, that's how I found them.
Old Oct 19, 2011 | 06:01 PM
dennis5374's Avatar
Funny because I was skeptical about using them. Terrible reviews online. My friend has a 1000 hp cutlass and he only deals with Ohio crankshaft.
Old Oct 19, 2011 | 07:08 PM
jaben2's Avatar
I am in the same boat as the op. I dropped the block off to the machine shop to get baked, and magged. Those look like a good setup. Another one I will have to consider for my build. Lucky for me, they are only about 2 hrs from me.
I might look at the 383 small block super kit.
Jeff1904
Jun 5, 2016 05:00 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
