Need Advice on Timing Set
Old Dec 14, 2005 | 12:31 PM
warbird27's Avatar
I'm doing a H/C package over the winter and I'm all setup except for the timing set. I'm not sure what I need and what brand. Im going to order a meziere ewp and was wondering if i need the WHOLE GM LT4 extreme duty timing set?? and if so, should i go with this or cloyes double roller or comp??
Old Dec 14, 2005 | 12:36 PM
BlkLT1Z28's Avatar
Re: Need Advice on Timing Set
Well, since your going with an EWP then dont even look at the LT4 set. I would go with the Cloyes DR.
Old Dec 14, 2005 | 02:54 PM
warbird27's Avatar
why shouldnt i llok at the lt4 set? i thought it was a double roller also.
Old Dec 14, 2005 | 03:06 PM
BlkLT1Z28's Avatar
no the lt4 xd is a single roller, the reason its so expensive is that it includes the gears to still drive the water pump. So if you have an ewp then problem solved.
Old Dec 14, 2005 | 06:14 PM
96flame's Avatar
I beleive that the timing cover needs a slight modification and deletion of the crank sensor for the double roller. Thats what I'd go with if your using an EWP though.
Old Dec 14, 2005 | 06:21 PM
turbo_Z's Avatar
Yeah the cloyes requires clearancing the timing cover a little. Nothing major if you have the right tools. The cloyes set is considerably cheaper than the LT4 and easily as strong if youre worried about that. The pn for the Cloyes chain is 3145.
Old Dec 14, 2005 | 07:20 PM
warbird27's Avatar
do i need anything else besides the chain, such as cam or crank sprocket??
Old Dec 14, 2005 | 07:27 PM
96flame's Avatar
Yeah buy the set
Old Dec 14, 2005 | 07:40 PM
warbird27's Avatar
is the comp cams set just as good as the cloyes??? the guys doing my heads keep the comp cams one on their shelf, so it would save me a lil with freight. also since i would have to modify the timing cover, should i just buy another one that doesn't need any modifications for safety purposes??? is their any timing covers out their for our cars that don't need modified for a double roller??? sorry for all the tedious questions, i just don't want to run into any bumps along the way.
Old Dec 15, 2005 | 12:12 PM
warbird27's Avatar
bump
Old Dec 15, 2005 | 01:02 PM
jerrysta's Avatar
I have been researching the same thing. I think you will need to modify the cover. I have not seen any that are alreay clearanced to use the EP set up.
I could be wrong, though. I'm sure someone else will chime in.
Old Dec 15, 2005 | 01:08 PM
RamAir95TA's Avatar
Never seen the Comp set, but it has to be within the price range of the Cloyes. The Cloyes is $80 and is extremely strong. I am using one on my engine.
For modifying the timing cover, all you need is a Dremel or a grinder and about 5 minutes. No sweat.
Old Dec 15, 2005 | 01:47 PM
NOMAD's Avatar
Stick with the Cloyes set. It's a true roller. The comp probably is just a double roller. If you had a part number that would help.
Mentioned before about the cam position sensors, you dont' need to even worry about that because you car is a 95 and OBD1.
Part number for the Cloyes you want is CLO-9-3145 Buy it through Summit Racing, theirs is the cheapest. www.summitracing.com
-Shannon
Old Dec 15, 2005 | 07:46 PM
warbird27's Avatar
actually my car is a 97 and obdII. the part number for the comp cams is 3136 and would cost me 60 bucks. or should i just go with the cloyes.
Old Dec 15, 2005 | 08:02 PM
94 guy's Avatar
check out the summit brand sum-g6601.
